ÆÛÇÃÆ÷·³
°øÁö [SynchroMax ]   ¼öµ¿¹Ì¼Ç,Æ®·£½ºÆÛÄÉÀ̽º,µðÆÛ·±¼È ¿ÀÀÏÀû¿ë ±Ô°Ý
2013-04-23 15:04   ´ñ±Û:4  ÀÐÀ½:10589
·Î¾âÆÛÇà ¼öµ¿¹Ì¼Ç,Æ®·£½ºÆÛÄÉÀ̽º,µðÆÛ·±¼È Á¦Ç° Àû¿ëÇ¥
Manual Transmission, Transfer Case, Differential Lubricant Cross-Reference
    Royal Purple
Application OEM Spec #/Part # Recommended Aggressive/Race
Audi/VW G-052-145 Max Gear 75W-90
BMW/Mini Green Label (Mobil SHC 630) Max Gear 75W-90
  Red Label (Dexron III) Synchromax
  No Label (80W GL-4) HPS 5W-30 XPR 5W-20
  1993 -1997 (Dexron III) Synchromax
  1998 & up (Mobil SHC 630) Max Gear 75W-90
  Esso MTF-LT-1, MTF-LT-2 Synchromax
  MTF LT-3 Synchromax
  MTF-94 XPR 5W-20 Synchromax
  Castrol SAF-XJ (limited-slip) Max Gear 75W-140
  Castrol SAF-XO Max Gear 75W-90
Chrysler/Jeep 75W-90 GL-3 HPS 10W-40 XPR 5W-30
  04873167 Synchromax
  04874459 Max Gear 75W-90
  04874464 Synchromax
  04874465 Synchromax
  04874469 Max Gear 75W-140
  05016796AA SynTractor III **
  05170055AA Mopar Transfer Case Lube OEM Fluid
  05179014AA Synchromax
  Jeep NV 247 transfer case SynTractor III **
  MS-10216 SynTractor III **
  MS-9224 Synchromax
  MS-9417 Synchromax
  NV4500 5-spd (75W-85) Max Gear 75W-90
  Viper Trans, 1993 (DEX III) Synchromax
  Viper Trans, 1994 & up (75W-85) Max Gear 75W-90
Ford Motor Co ESP-M2C166-H Mercon Synchromax
  F32Z 19C547 Max Gear 75W-90
  XL-12 Synchromax
  XT-2-QSM Synchromax
  XT-5-QM Synchromax
  XT-M5-QS HPS 10W-40 XPR 5W-30
  XT-11-QDC Synchromax
**  Industrial RP Fluid; smallest container is 5-gallons; recommend using factory fluid
    Royal Purple
General Motors SAE 80W-90 Max Gear 75W-90
  GM 1052931 HPS 5W-30 XPR 5W-20
  GM 12345349 (Synchromesh) Synchromax
  GM 12345577 Synchromax
  GM 12346190 (SynTorque LT) Max Gear 75W-90
  GM 1235977 Max Gear 75W-90
  GM 12377916 (Synchromesh) Synchromax
  GM 12378261 Max Gear 75W-90
  GM 12378396 Synchromax
  GM 12378505 Synchromax
  GM 12378508 Synchromax
  GM 12378514 Synchromax
  GM 12378515 Synchromax
  GM 12378557 (QuadraSteer) Max Gear 75W-90
  GM 19259104 HPS 5W-30 XPR 5W-20
  GM 21018899 HPS 5W-30 XPR 5W-20
  GM 88861800 Synchromax
  GM 88862472 or 88862473 HPS 5W-30 XPR 5W-20
  GM 88900402 Synchromax
  GM 89021677 Max Gear 75W-90
  GM 89021806 HPS 10W-40 XPR 5W-20
  AutoTrak II Synchromax
  BOT 0063 HPS 5W-30 XPR 5W-20
  MTF 0063 HPS 5W-30 XPR 5W-20
  Saab 12799117 HPS 5W-30 XPR 5W-20
  Saturn 21005966 Synchromax
  Saturn MTF HPS 5W-30 XPR 5W-20
  VersaTrak fluid Synchromax
Honda/Acura Honda MTF #08798-9031 HPS 5W-30 Synchromax
  Acura #08798-9016A HPS 5W-30 Synchromax
  Honda VTM-4 OEM Fluid
Hyundai SAE 75W-85 (6-spd manual) HPS 10W-40 Synchromax
Jaguar/Land Rover Shell TF 0753 Synchromax
  Shell Spirax TS 90 Max Gear 75W-90
  Castrol SAF XO Max Gear 75W-90
  Castrol SAF Carbon Mod Max Gear 75W-90
    Royal Purple
Mercedes Benz/ MB 000 989 2603 Synchromax
Smart Car MB 001 989 2603 Synchromax
  MB 001 989 1703 (Hypoid Gear Oil) Max Gear 75W-90
  Shell ATF 3403 M115, MB 236.10, NAG1 Max ATF
  Fuchs ATF 3353, MB 236.12 Max ATF
  Fuchs Titan ATF CVT, MB 236.20 CVT, use OEM fluid
  Castrol Manual BOT 328 Max Gear 75W-90
Mitsubishi Texaco MTX Fluid FM XPR 5W-20 Synchromax
Porsche 000 043 300 38 Synchromax
  000 043 304 71 HPS 10W-40 XPR 5W-30
  000 043 300 37 Max Gear 75W-90
  Castrol BOT 338 (75W-80) Synchromax
  Shell Spirax S5 ATE 75W-90 HPS 10W-40 XPR 5W-30
  Burmah Carbon Mod 75W-90 Max Gear 75W-90
Toyota V-160, 08885-01306 ('93 & up Turbo Supra) Synchromax
¿¬ºñ¿ÕÀÇ ¿¡ÄÚµå¶óÀ̺ù ºñ¹ý !!! ¿ÀÀÏÇÊÅÍÀÇ Á߿伺
2013-04-24 09:10 882971P
ÈÀ´ÙÀ̰¡ º¸À̳׿ä~!
2013-04-24 16:54 1425671P
Çö´ëÀÚµ¿Â÷ 6´Ü¼öµ¿ ¹Ì¼Ç¿ÀÀÏÀº HPS10W40À̳ª °ø°ÝÀû(°ÅÄ£)ÁÖÇàÀ̳ª ·¹À̽̿ëÀ¸·Î´Â  Synchromax¸¦ »ç¿ëÇ϶ó³×¿ä ^^;;
2014-03-05 11:58 882971P
¼öµ¿¹Ì¼Ç¿ÀÀÏÀ»... 10w40À» ½áµÎ µÇ³ª¿ä???? ;;;
2014-03-05 12:15 1425671P
 Á¤ÁöÈÆ´Ô  ³× »ç¿ëÇØµµ(Ãßõ) µÈ´Ù°í Çϳ׿ä~ Synchromax´Â Çö´ëÂ÷¿¡ Àû¿ëÇϽŠºÐµéÀÌ °è½Ê´Ï´Ù~
