Áú¹®°ú´äº¯
[Max-Gear 75W90]   LSD¿ÀÀÏ?
±è¼º±Ô|ÀÌŬ¸³½º
2011-05-14 08:40   ´ñ±Û:5  ÀÐÀ½:3345
ÃßõÇÑ±Û 7
LSD¿ÀÀÏ·Î MAX GEAR 75W90 ½áµµµÇ³ª¿ä?
HPS´Â 0W40 Á¦Ç°Àº ¾ø´Â°Ç°¡¿ä? »çÀºÇ°ÀÌ Ã·ºÎ°¡ ¾ÈµÇ¾ú½À´Ï´Ù..;;
2011-05-14 11:17 1423864P
MAX-GEAR´Â ±â¾î°èÅë¿¡ Àû¿ëµÇ´Â À±È°À¯ ÀÔ´Ï´Ù.
±â¾î°èÅëÀÇ À±È°À¯´Â auto transmission fulid, manual transmission fulid, transfer case, excelsµî ¿©·¯ Àû¿ëÇüŰ¡ ÀÖ½À´Ï´Ù.
LSD´Â excels°èÀÇ ¿ÀÀÏ(ÀϹÝÀûÀ¸·Î µ¥ÈÄ¿ÀÀÏÀ̶ó ĪÇÏÁÒ)ÀÌÁö¸¸ µ¥ÈÄ¿ÀÀϰú´Â ´Ù¸¥°ÍÀ¸·Î ¾Ë°í ÀÖ½À´Ï´Ù.
MAx-Gear´Â API ±Ô°Ý GL-4,GL-5Ç¥ÁØÀÌ Àû¿ëµÇ¾î ÀÖ°í LSD¿ÀÀϵµ ÀÌ ±Ô°Ý¸¦ µû¸£´Â°ÍÀ¸·Î ¾Ë°í ÀÖ½À´Ï´Ù.
´Ö»êÀÚµ¿Â÷Æ÷·³ÀÇ Max-Gear LSDÀû¿ë¿¡ °üÇÑ ³»¿ë ÀÔ´Ï´Ù. ÂüÁ¶ ÇϽñ⠹ٶø´Ï´Ù.
have been using Royal Purple products for years with no problems and 175K on a 1990 Pathfinder with LSD. No, I do not sell or make anything off this post, just a satisfied customer. Royal Purples gear lube is synthetic and is rated as GL-4and GL5. The clutch or cone type refers to the different types of Limited Slip Differential drive connections. Here is a snip from the site I pasted below: Royal Purple Consumer Automotive Product Line
Max-Gear is recommended for use in truck, motor home / RV, and automotive front or rear differentials, manual transmissions and lower gear units of marine engines that specify use of an API GL-5 or GL-4 fluid.
Max-Gear is an ultra-tough, high performance, GL-5 automotive gear oil designed to provide maximum protection to heavily loaded gears while maximizing power output throughout the drive train. It outperforms other GL-5 gear oils because it combines the highest quality synthetic oils with Royal Purple¡Çs proprietary Synslide additive technology.
Max-Gear makes gears run smoother, quieter, cooler and longer without overhauls.
All viscosities of Max-Gear are formulated with hypoid friction modifiers necessary for use in clutch or cone type differentials. No additional additives are necessary.
I hope this helps. Also there is a product called Red Line I have seen posted before but have never tried this product. Good Luck..
±è¼º±Ô|ÀÌŬ¸³½º
2011-05-14 20:02 133169P
Á¨Äò LSD°¡ GL-5±Ô°ÝÀÌ´Ï »ç¿ëÇØµµ µÇ´Â±º¿ä
¿£Áø¿¡ ÀÌ¾î ¹Ì¼Ç LSDµµ...
2011-05-15 11:08 1423864P
ÇÊ¿äÇϽǶ§ ¿¬¶ô ÁÖ¼¼¿ä~~^^
2011-10-06 16:38 882971P
±Ùµ¥ lsd´Â ¹¹±¸.. µ¥ÈÄ¿ÀÀÏÀº ¹º°¡¿ä??
¶ó¼¼Æ¼¿¡µµ µ¥ÈÄ¿ÀÀÏ? ÀÌ ÀÖ³ª¿ä?
2011-10-06 16:45 1423864P
Àúµµ ÀÚ¼¼È÷´Â ¸ð¸£Áö¸¸ LSD´Â ¾çÂÊÀÇ ±¸µ¿(¹ÙÄû)ÀåÄ¡¸¦ Á¶ÀýÇÏ´Â ½Ã½ºÅÛÀ¸·Î ¾Ë°í ÀÖ½À´Ï´Ù. ÄڳʸµÀ» ÇÒ¶§ ¾ÈÂÊ ±¸µ¿°ú ¹Ù±ùÂÊ ±¸µ¿À» ÀûÀýÈ÷ Á¶ÀýÇÏ¿© °¡¼Ó¼º´É ¹× ¾ÈÁ¤¼ºÀ» À¯ÁöÇÏ´Â °Í...±×·¸°Ô ¾Ë°í ÀÖ½À´Ï´Ù. µ¥ÈÄ´Â ÈÄ·û±¸µ¿Ãà, Æ®·°À» º¸°ÔµÇ¸é µÚÂÊ ±¸µ¿ÀåÄ¡¿¡ º¹¼þ¾ÆÃ³·³ µÕ±×·± ÀåÄ¡¸¦ µ¥ÈĶó°í ¾Ë°í ÀÖ±¸¿ä~ ¶ó¼¼Æ¼´Â µ¥Èİ¡ ¾ø°ÚÁÒ? ^^
