[±âŸÂ÷Á¾ ]
[Max-Gear 75W90]
¸Æ½º±â¾î ±³Ã¼ Èıâ.
´ñ±Û:8
ÀÐÀ½:7739
882971Æ÷ÀÎÆ®
364°Ô½Ã±Û
6489´ñ±Û
ÃßõÇϱâ
1
2014-03-22 10:47 882971P
À½...
»ç½Ç ·Î¾âÆÛÇÃÀÌ ¶¯±â´Â°Ç »ç½ÇÀε¥ ½ÌÅ©·Î¸Æ½º´Â ¾î¶³±î¿ä? ... ÂÁ.
2014-03-22 11:11 882971P
½ÌÅ©·Î¸Æ½º ÆøÇ³ ±¸±Û¸µÁßÀÔ´Ï´Ù
À̳༮ Á¡µµ´Â ¾îÂîµÇ´Â°¡¿ä? gl4±Ô°ÝÀΰ¡¿ä?
ÀÌ·¡Àú·¡ Á» ¾Ë·ÁÁÖ¼¼¿ä ¤Ð.
2014-03-22 13:16 1423994P
½ÌÅ©·Î¸Æ½º´Â ¼öµ¿º¯¼Ó±âÀÇ Æ¯Á¤±Ô°Ý¿¡ ´ëÇØ Áøº¸ÀûÀ¸·Î ÀÀ¿ëµÈ Á¦Ç°À̶ó°í º¸½Ã¸é µË´Ï´Ù. XPRÀÌ µî±ÞÀÌ ¾øµí ½ÌÅ©·Î¸Æ½ºµµ µî±ÞÀº ¾ø½À´Ï´Ù.
½ÌÅ©·Î¸Æ½º´Â BMW¿À³ÊºÐµé²² ¸¹ÀÌ ¾Ë·ÁÁ® ÀÖ´Â Á¦Ç°ÀÌ¸ç ±¹³»Â÷Á¾¿¡´Â Çö´ëÂ÷ÀÇ °æ¿ì °¡È¤/·¹À̽̿¡ ÀûÇÕÇÏ´Ù°í ÃßõµÇ¾î ÀÖ±¸¿ä Á¡µµµµ Ç¥±âµÇ¾î ÀÖÁö ¾Ê½À´Ï´Ù. µ¥ÀÌÅÍ½ÃÆ®¸¦ »ìÆìº¸¸é 100µµ 7.7 Á¤µµÀ̰í max-gear75W90ÀÌ 17.5Á¤µµ µË´Ï´Ù.
¼ÖÁ÷È÷ Synchromax¿¡ ´ëÇÑ Á¦Ç°ÀÇ ÀÌÇØ´Â Àúµµ ¾ÆÁ÷ ¹Ì¹ÌÇÑ ¼öÁØÀÌ¸ç »ç¿ëÀںеé°úÀÇ
ªÀº ´ëȸ¦ ÅëÇØ¼ Á¶±Ý¾¿ ¾Ë¾Æ°¡±â´Â ÇÏÁö¸¸, ³Ê¹« ¾î·Á¿î Á¦Ç°ÀÔ´Ï´Ù.^^
ZF TE-ML 17a( MIL-L-2105)´Â GL-4±Ô°ÝÀ̸ç À̱԰ݰú Synchromax¿¡´ëÇÑ
·Î¾âÆÛÇû翡 ´ÙÀ½°ú °°Àº ÁúÀÇÀÀ´äÀÌ ÀÖ½À´Ï´Ù.
Hi,
I wish to change the transmission oil in my 2004 BMW M3. It has the SMG 6 speed manual transmission and calls for bmw mtf-lt-2, as per the service manual. This appears to be fully synthetic gear oil, 75W-80, API GL4, MIL-L-2105.
Which Royal Purple product is correct for this application?
I see several folks have used the Synchromax Manual Transmission Fluid, but I am concerned that it may be too thin for this application.
It also states this is for manual transmissions that call for an ATF fluid.
Would the Max Gear Synthetic Gear Oil 75W90 be a better choice?
Thanks,
Good morning,
You are correct, your 2004 BMW M3 – SMG 6-speed manual transmission does uses BMW MTF-LT-2 fluid. This is a light viscosity fluid and should not be mistaken for a gear oil. We recommend Royal Purple Synchromax (part #01512, quart bottle) to replace BMW (Esso) MTF-LT-1, MTF-LT -2, and MTF-LT -3 fluids. It work great in your BMW manual transmission and also in hot climates. You need 1.8 quarts.
Thank you for choosing Royal Purple and have a great day!
Best Regards
Steve Mathews
Technical Services
Royal Purple Inc.
281-354-8600
¾È³çÇϼ¼¿ä
Á¦Â÷·®ÀÎ 2004 BMW M3¿¡ º¯¼Ó±â ¿ÀÀÏÀ» ±³È¯ÇÏ°í ½Í½À´Ï´Ù.
SMG 6´Ü ¼öµ¿ º¯¼Ó±âÀ̸ç BMW MTF-LT-2, ¼ºñ½º ¸Å´º¾ó¿¡´Â ÇÕ¼º±â¾î¿ÀÀÏ 75W-80, API GL4, MIL-L-2105ÀÌ Ç¥±âµÇ¾îÀÖ½À´Ï´Ù.
·Î¾â ÆÛÇÃÀÇ Àû¿ë°¡´ÉÇÑ Á¦Ç°Àº ¹«¾ùÀԴϱî? ³ª´Â ¸î »ç¶÷µéÀÌ Synchromax ¼öµ¿ º¯¼Ó±â ¿ÀÀÏÀ» »ç¿ëÇϴ°ÍÀ» º¸¾ÒÁö¸¸
³»°¡ °ÆÁ¤Çϴ°ÍÀº Synchromax°¡ ³Ê¹« ¾ãÀºµíÇϸç(Á¡µµ¸¦À̾߱âÇϴµí) ATFÀ¯Ã¼¸¦ ¿ä±¸ÇÏ´Â ¼öµ¿º¯¼Ó±â¿¡ Àû¿ëÇϴµí ÇÕ´Ï´Ù.
¿ÀÈ÷·Á Max gear 75W90ÀÌ ´õ ³ªÀº ¼±ÅÃÀÌ µÇÁö ¾ÊÀ»±î¿ä?
°¨»çÇÕ´Ï´Ù.
ÁÁÀº ¾ÆÄ§ ÀÔ´Ï´Ù.
2004 BMW M3 - SMG 6´Ü ¼öµ¿º¯¼Ó±â´Â BMW MTF-LT-2 À¯Ã¼¸¦ »ç¿ëÇÕ´Ï´Ù.
ÀÌ Á¡µµÀÇ ¿ÀÀϰú ±â¾î ¿ÀÀÏ¿¡ ´ëÇÑ ¿ÀÇØÇØ¼´Â ¾ÈµÈ´Ù.
¿ì¸®´Â BMW (esso) MTF-LT-1, MTF-LT -2, ±×¸®°í MTF-LT -3 ¾×ü¸¦ ´ëüÇÏ´Â
·Î¾â ÆÛÇà Synchromax (ºÎǰ ¹øÈ£ : 01512, ÄõÆ®)¸¦ ÃßõÇÕ´Ï´Ù.
Synchromax°¡ BMWÀÇ ¼öµ¿º¯¼Ó±â¿Í °í¿¿¡¼ Àß ÀÛµ¿ÇÕ´Ï´Ù.
´ç½ÅÀº 1.8 ÄõÆ®°¡ ÇÊ¿äÇÕ´Ï´Ù.
·Î¾â ÆÛÇÃÀ» ¼±ÅÃÇØ Áּż °¨»çÇϰí ÁÁÀº ÇÏ·çµÇ¼¼¿ä
½ºÆ¼ºê ¸ÅÆ©½º ±â¼ú ¼ºñ½º
·Î¾â ÆÛÇà inc.
281-354-8600
°á·ÐÀº MIL-L-2105±Ô°Ý¿¡ Max Gear 75W90º¸´Ù´Â Synchromax¸¦ ÃßõÇϳ׿ä
Á¡µµÁö¼öµî¿¡ ´ëÇØ¼´Â ¿°·ÁÇÒ Çʿ䰡 ¾ø´Ù°í Çϳ׿ä^^;;
2014-03-22 13:19 1423994P
±×·±µ¥ max gear¸¦ ³Ê¹« »¡¸® »©½Å°Å ¾Æ³é¿ä?^^
¾Æ±õ;;;;
2014-03-22 14:09 882971P
¾Æ±î¿î °Ç ´ç¿¬ÇÑ »ç½ÇÀÌÁÒ... ¤Ð¤Ð.
ÇÑ°Ü¿ï ¿ÜºÎÁÖÂ÷ÇÏ¸é ³Ã°£½Ã ³Ê¹« »¶»¶Çؼ °í»ýÁ»Çß¾úÁö¸¸ ÀÌÁ¦ °Ü¿ïµµ Áö³ª°¬´Â°É¿ä.
´Ù¸¸ ±â¾îº¯¼Ó½ÃÀÇ ´À³¦ÀÌ Ã³À½°ú ´Þ¸® ¾ÈÁÁ¾ÆÁö´Â°Í°°¾Æ¼ ±³Ã¼¸¦ °¨ÇàÇß½À´Ï´Ù.¤Ð
¿îÀüÀº Áñ°Å¿òÀε¥. ±×·¸Áö°¡ ¾Ê¾Æ¿ä. »ç½Ç ÀÌ°Ô gl5°â¿ë±Ô°Ý¶§¹®ÀÎÁö´Â ¸ð¸£´Â°ÍÀÔ´Ï´Ù¸¸...~
´äº¯ÁֽŰͰú ¿©·¯Æ÷·³µé µÚÁ®º¸´Ï ¾Æ¹«·¡µµ ½ÌÅ©·Î¸Æ½º°¡ ´õ ÀûÇÕÇÑ ³à¼®°°±äÇѵ¥,
ÇöÀç¿ÀÀÏ Áֱ⸦ Á» ª°ÔÀâ°í ½ÌÅ©·Î¸Æ½ºµµ Àû¿ëÇØºÁ¾ß°Ú¾î¿ä.
¾Æ½Ã°ÚÁö¸¸...Á¦°¡ ±Ô°ÝµûÁö±â¸¦ ÁÁ¾ÆÇÏÁø ¾Ê¾Æ¼ °³ÀÇÄ£¾ÊÀºµ¥, ¾Æ´Â ¹Ù°¡ ¿ö³« ¾ø°í º¯¼Ó°¨¼º(?)ÀÌ ÀÛ¿ëÇÏ´Ùº¸´Ï ±Ô°ÝºÎÅÍ Á¢±ÙÇÏ´ÂÁßÀÔ´Ï´Ù ¤¾¤¾
2014-03-22 14:25 1423994P
¾Æ´Â¹Ù°¡ ¾ø´Ù´Â°Ç;;;;¤¾¤¾
ÀúÀÇ ´ñ±ÛÀº ¸Þ´º¾ó°ú ºñ±³Àû »ç½Ç°ú °¡±î¿î ÀڷḦ ã¾Æ¼ ¿Ã¸®´Â°Í»Ó!
Â÷·®¿¡ Àû¿ëÇϰí Á¦Ç°ÀÇ ¼º´É°ú Ư¼ºÀ» ÆÇ´ÜÇÏ´Â°Ç ¾Æ¸¶ ÁöÈÆ´ÔÀÌ 1000¹èÁ¤µµ ³´´Ù°í º¾´Ï´Ù
ÀúÈñ ȨÆäÀÌÁö ´Ù¸¥ ȸ¿ø´Ôµéµµ ´ë´Ù¼ö ±×·¯Çϱ¸¿ä ¤¾¤¾
½ÌÅ©·Î¸Æ½º, ¸Æ½º±â¾îµîÀº Àúµµ »ç¿ëÇØº¸Áö ¸øÇÑ ¿ÀÀÏÀ̶ó »ç¿ëÀÚ°æÇèÀ» µè´Â°ÍÀÌ °¡Àå Å©±¸¿ä
Á¦ »ý°¢Àº ½ºÆ¼¾î¸µ¿ÀÀÏÀÇ °æ¿ì ATF±Ô°ÝÀ̶ó ¿ÀÅä¹Ì¼Ç¿ÀÀÏÀ» ¸¹ÀÌ Àû¿ëÇÏÁö¸¸, MAX EZ¶ó´Â Àü¿ë¿ÀÀÏ Ã³·³
½ÌÅ©·Î¸Æ½ºµµ ¼öµ¿¹Ì¼ÇÀü¿ë¿ÀÀÏÀÌ¶ó º¸¿© Áý´Ï´Ù. ´ÜÁö, ¹Ì¼ÇÀÇ Æ¯¼º»ó ±Ô°Ý°úÀÇ È£È¯¿©ºÎÀ» ¾Ë±â°¡ ¾î·Æ´Ù´Â
Á¡ÀÌ¸ç ¾Æ¸¶ ÀÌ·± ºÎºÐµéÀ» ÀÚ·á·Î ü°èÈÇÏ¿©¾ß Çϴµ¥... ½ÇÁ¦·Î´Â ¼öµ¿À¯Àú°¡ Á¡Á¡ °¨¼ÒÇÏ´Â Ãß¼¼¶ó
¼ö¿ä°¡ ³Ê¹« ¾ø´Ù´Â°ÍÀÌ ¹®Á¦ ÀÔ´Ï´Ù. »ç½Ç ǰÀýÀÌÈÄ ÀÔ°í ¿©ºÎ¿¡ ´ëÇØ °í¹ÎÀ» ¸¹ÀÌ Çß¾ú´Âµ¥¿ä.
ȸ¿øºÐ²²¼ ÀÛ³âºÎÅÍ ¿äûÀ» Çϼż ÀÔ°í¸¦ °áÁ¤ÇÏ°Ô µÇ¾ú½À´Ï´Ù^^ ¤¾¤¾
Á¦ÃßÃøÀ¸·Î´Â Á¦Ç°ÀÇ Æ¯¼ºÀº max gearº¸´Ù´Â »ó´çÈ÷ ºÎµå·¯¿ì¸é¼ ¿¾ïÁ¦¿Í ³»±¸¼ºÀÌ ¶Ù¾î³¯°ÍÀ¸·Î º¸ÀÔ´Ï´Ù.
2014-03-22 15:17 882971P
³×~! ´äº¯°¨»çÇÕ´Ï´Ù~!
´Ù °í·ç°í·ç °®Ãç¾ßÁÁÀº°Çµ.... Áö½ÄÀº ¾è½À´Ï´Ù^^; »ç¿ëÇϰíºñ±³Çϴ°ÇÁñ°Å¿îµ¥ °øºÎÇϴ°Ç... ¸Ó¸®°¡. ¤¾¤¾¤¾
¾Æ¸¶ ±Ø¾Ð÷°¡Á¦ ºÎºÐÀÌ Â÷À̰¡ ³¯ µíÇϳ׿ä~ ³»±¸¼ºµµ Â÷À̳¯Å×±¸¿ä~
½ÌÅ©·Î¸Æ½º ¾î¼ Àû¿ëÇØº¸°í½Í³×¿ä~ ÇÏÁö¸¸ ¾îÁ¦ÀÛ¾÷ÇÑ°É »©°í ½ÌÅ©·Î¸Æ½º ±¸ÀÔÇÏÀÚ´Ï... ÂÍ ¾Æ±õ°í~
¼öµ¿¿À³Ê°¡ Á¡Á¡ÁÙ¾îµéÁÒ..¤Ð
Àúµµ ¸î³âÀü¸¶À½°ú Áö±ÝÀº Á» ´Ù¸¨´Ï´Ù.. 20´ë¸¸Ç߾ Æò»ýÀ» ¼öµ¿Å¸¾ßÁö Çߴµ¥,, Áö±Ý¿Í¼´Â ¾ÆÁ÷Àº Ÿ´õ¶óµµ ³ªÀ̵é¸é ¸ð¸£°Ú´Ù. ..¶ó´Â;;
¹¹.. ¿©·¯ Â÷Á¾ °Ë»öÇÏ¸ç ¿¡À× ¼öµ¿ÀÌ ¾ø³× .. ±×·³ Á¦¿Ü!! ¾ÆÁ÷Àº.. ÀÌ·±´Ü°è±ä ÇÕ´Ï´Ù¸¸ ¤»¤»¤»
Â÷¶ó´Â°ÅÀÌ ¿îÀüÀÌ ÁÖ´Â Áñ°Å¿òº¸´Ù´Â, ÆíÇÑÀ̵¿¼ö´ÜÀÌ µÈ´Ù¸é... µÚµ¹¾Æº¼°Íµµ¾øÀÌ ¼öµ¿À» ¹ö¸®°ÚÁÒ..
ÇÑ»ç¶÷ÇÑ»ç¶÷ ÀǰßÀ» ¹Ý¿µÇØÁÖ½Ã´Ï ¸É¹ö½º°¡ ÁÁÀ»µû¸§ÀÔ´Ï´Ù. 10-47ÇÊÅ͵µ ±×·¸Áö¿ä^^
2014-03-25 19:32 66985P
Á¤¸» ±ä±ÛÀ̾ú½À´Ï´Ù.
¿ª½Ã ·Î¾âÆÛÇÃÀ̱º~ÇÏ´Â ´À³¦À» ¹Þ³×¿ä
